"Greg58;565180]If you read the post above I tried.
Below is a helicoil that is not that expensive. But you have to buy the tap, it was way cheaper to replace it."
Ok so the clutch couldn't have been the issue that's one down head gasket could attribute to the issue as well two down, What about over torquing the head bolts or the spark plug hole being to narrow?
Something changed the day the spark plug blew out. I believe that torquing the head to it's proper torque caused that, or I just had a weak or bad head.
Also when I took the old head off I noticed the head gasket had a piece of metal that had been cut and was sticking up, this may have caused a leak or an opening and in relation lower compression and I think that caused to much compression, or I just got a bad head but the plug popped off the very day I bought my torque wrench and I had a mechanic show me how to use it and he helped me torque it on then it happened on the way home from Canadian Tire.
Maybe you can answer a couple more questions, It seems that if you take the muffler cap off the bike it's obviously louder but it also seems to have more power and speed is this normal?
I have also wondered why I have never been able to get the speed that some report they get on their bikes with the same setup one guy wrote " a finely tuned, bone stock kit and sprocket will easily do 35 mph" that's 56 kmh and that is 10 kmh faster then I have ever gotten, does this help point to any previous issue or is it just due to break-in?
I think I got unlucky and got a bit of a lemon, I have had issues from day 1 but my uncles kit had no issues. I think I am close to getting the problems ironed out. My biggest problem is as I have said, I don't quite understand how each part relates to one another like what can cause what. In a computer I know what each chip and part do and what will happen if you change any one of those parts with the motor I didn't know what the clutch would cause if it was to tight etc.
I believe once I understand what each part does in relation to the overall performance and running, then I can figure out what happened or what is happening. If that makes any sense.
