This is the best translation i could find for the carb info. thought it might help
Ping PZ15J suction plunger-type carburetor
形式与用途 Forms and uses
PZ15J化油器是平吸柱塞式化油器,主要与建设CY-50、CY80摩托车相配套,也可用于IE47FM的发动机。 PZ15J carburetor is flat suction plunger-type carburetor, mainly related to the construction of CY-50, CY80 motorcycle match can also be used to IE47FM engine.
主要结构尺寸 The main structure of size
混合室出口直径: ¢15 Mixing chamber exports the diameter: ¢ 15
安装尺寸: ¢21 Installation Size: ¢ 21
外形尺寸
长×宽×高)74×59×122 Dimensions: (L × W × H) 74 × 59 × 122
主要技术参数 Main technical parameters
最大功率: 4.9KW/6000r/min Maximum Power: 4.9KW/6000r/min
最大扭矩: 8.0Nm/4500r/min Torque: 8.0Nm/4500r/min
经济油耗: 1.9L/100Km Fuel economy: 1.9L/100Km
发动机最低稳定转速: 1500±150r/min Minimum stable engine speed: 1500 ± 150r/min
外形尺寸
