That's good - thanks!!!From the plate to bar is probly 12 1/2 to 13 inches.The mount is probly another 3 inches.If you need exact numbers It will have to wait til morning.
Thanx.. Rear hub is a Sturmey 5 speed internal (5xrd I think)70mm drum.( Cartman ) SUPERSWEET !!Couple O questions. What rear hub are you using? What's the hangy downy thingy on the rear axle?? is the extra lever on the R side of the handlebar something to do with the rear hub? AND is that a Sick Bikes freewheel setup on the peddle crank???? Loving this build and its coming together quick! Good job Moto!
Thanx..I hope so he's a good guy with good prices!People are commenting on the Silver State Name on the tank. It comes bare from SSC. I put the name on tank.Just like my last 3 builds.very cool....youre gonna sell alot of bikes for Scott!
Loving this build.Thanx..I hope so he's a good guy with good prices!People are commenting on the Silver State Name on the tank. It comes bare from SSC. I put the name on tank.Just like my last 3 builds.
Please post some close up pics of the seat.Gettin closer Scott at SSC cover my seat and it came out great!!.
Thanks....I have only got to 3 rd gear so far.Having problems with the torque pulling my.jackshaft when I get on the gas. I will be working on it this week. Will update with some finished build photos and some good jackshaft news!Looks sooo good, waiting for riding impression..![]()
Yep I know what you mean about damaging seat post tube.If I would have thought about it more the seat tube would have had a solid section. So I could class.l the bajesus out of it. Now I'm trying the clamp section on both side with bolts pulling them together.It's good waiting for good news.
On my 99cc build, I was having the same problem of the torque twisting and moving the shaft. I kept tightening the clamps, and it helped for awhile, and it started to get worse and worse. When I first took it apart, I found that the u-bolt started to marred into the paint. I tighten a little more without thinking about it. I kept tightening it up for awhile. It started to get worse,I took it apart and found that the seat tube was cringe. I think that's when it started to get worse progressively. I filled up the cringe location with some welding and that fixed it for about 60miles or so. I'm now on a different set up for the 212. Anyhow, the U-bolts had very little surface are to bite into the seat tube, and can easily twist/turn with the torque of the motor.
I know scotto has really good clamps that bite into the seat tube instead of cringing it like the set up I had.
Would you be able to connect it to your motor mounting plate?
