mrfubs
so i bought the reed valve kit from arrow, im not 100% aware of what advantages the 3rd TP adds? also does it bypass the intake port? so as soon as the piston starts going twords TDC from BDC creating a burst of suction when the intake port is opened; is that burst of suction gone due to the 3rd TP? does the port minimize intake charge?
My exhaust timing question, would i get a better breathing engine if i widened the exhaust port? or should i change the timing by a few if bringing the port up a little higher with out achieving too high of rpm?
My question on a piston port, would drilling a medium/small size hole in direct correlation with the wrist pin bearing upon intake stroke would that help lube the wrist pin bearing? and also would or would that not work if i added a 3rd TP?
Thanks everyone!
Thanks everyone!
