I got this from the other forum."stuffing the crankcase" ? I sincerely hope you're not going to try using JB Weld. You'll be sorry.
Special quote for 2doorInsulting offers will be cursed to everlasting flames. I have spent untold hours getting this engine just right. The cylinder lost some flakes of chrome lining when part of the JBWeld I had glued to the interior of the crankcase (for more crank pressure) came off and got chewed up in the engine. Still runs great though.
My new crank from RSE is quite a bit narrower than my other 40mm cranks.
with only 6mm between flywheels as opposed to the usual 12mm.
Allowing for 5mm plates to be mounted to the cases.
This should give me considerably more primary compression.
