okay just took it out for its first ride and a few things I have noticedfor stuff it has about the same compression as the stock head that I got down well probably a little bit more which is good since I can continue running the same octane gas and fuel mix. NEX his the good part even know that is about the same compression as my old stock head it seems to produce overall a whole lot more torque in the midrange end of the line top end speed did not change it all .
even though I did not gain any type and speed from the head swap I did however I noticed that a lot of the vibrations I had at high RPMs with the old stock head are now gone I think this is due in part to The Squish band and chamber design in the new head.
so along with a lot of reduced vibrations and a heck of a lot of torque in the mid range in low end I am liking this head . this is the perfect high comp head for someone looking to build a torque monster.
I am running true fuel 92 octaine 40:1 andcit seems to be right on par ! All i had to do was adjust the idle a little bit. !
Again on my bike the puch 70cc hi hi gave me a little bit more than 11:1 comp, it reduced vibrations at all rpm's especialy under load, off the line torque increased noticably and midrange torque is off the charts, i didnt notice much on the top end but there is probably a little gain there to idk i have not opened her up to past 3/4 throttle yetbut will keep you updated. Also cooling had increased three fold due to the massive size of the head and cooling fins .
I think i will keep this head on my bike as a final part lol its part of the motor now not to be changed.
