chillphillyphil
I want a commuter that is reliable, easy to install, and maintain.
I have built four china dolls now all grubee skyhawk gt5s, but it's been my experience that they just aren't reliable enough as a commuter *still love them*, so no hate. It's just a pain to have to mix fuel, fix chains, and keep up with the many hicups these little motors provide.
When I saw there was a honda 4 stroke friction drive kit, I thought my prayers were answered. But I dare not venture forth without some input from my fellow forum friends, so please, if you have any experience with this kit or any sort of friction drive motor, please give me your input.
The 29inch Mountain Bikes I'm looking at:
http://www.bikesdirect.com/products/dawes/haymaker2900.htm
http://www.bikesdirect.com/products/gravity/29point1.htm
http://www.bikesdirect.com/products/gravity/g29ss.htm
http://www.bikesdirect.com/products/motobecane/329ht_29er_mountainbikes.htm
The Motor Kit:
http://cyclehappy.com/friction-driv...it-friction-drive-rear-mount-for-bicycle.html
The Motor Kit:
Description
Friction Drive Rear Mount Kit with the Honda GX35 35.8 cc 1.60 HP Four Cycle - 4 Stroke engine. This engine kit has the 76 mm clutch rotor - 78 mm clutch drum and can be ordered with five sizes drive rollers. The most common size for this engine is: 1-1/8".
This is a complete Rear mount friction drive kit that will mount to most Bicycles.
The kit includes:
One: Honda GX35 35.8 cc 1.60 hp Four Cycle Engine with engine manual.
One: Custom made 60" long throttle cable with the small lever & #16 mini hose clamp.
Four: 8” long Black Nylon ties to secure the throttle cable and stop switch wire to the frame.
One: Remote push button stop switch with connecting end.
Two: ¼” x ¾” x 15” long Aluminum flat bar, CNC machined and Black Anodized.
One: Alloy Skewer - Quick Release, 5m -.80 x 161mm with channel spacers and hardware.
One: "U" Bracket with backer plate, zinc plated with hardware
Four: 6mm x 1.0 x 40 mm Hex Head Bolts.
One: Engine spacer, steel, zinc plated.
One: 76 mm Clutch Drum with 3/8-24 right hand threads.
One: 5/16" Flat Washer - used as a spacer between the bearing and clutch drum.
One: 1/4" thick Aluminum Extrusion channel that is CNC machined and Anodized Black.
(Not a bent thin piece of steel like the others that have tried to copy my product)
Two: 5/8” ID x 1-3/8" OD x 7/16" wide High Speed Double Sealed Ball Bearings with retaining ring.
We use one High Speed Double Sealed Ball Bearing on each side of the Drive Roller to support it and remove all the pressure off the engine.
Most customers will need to order the 1-1/8" or 1-1/4" Max OD drive roller.
The 7/8" drive roller is good for riders over 250 lbs and / or if you have lots of hills with a top speed of about 22 mph. Mostly used with engines 1.10 HP and Higher.
The 1" drive roller is good for riders up to 200 lbs and some hills top speed is about 25 - 27 mph. mostly used with engines 1.10 HP and Higher.
The 1-1/8" drive roller is the standard and most common size for riders up to 280 lbs with mostly flat ground that want a fast top speed about 30 mph. Mostly used with engines 1.60 HP and Higher.
The 1-1/4" drive roller and for riders 165 lbs or less and mostly flat ground 33+ mph.
The 1-3/8" drive roller and for riders 150 lbs or less and mostly flat ground 37+ mph.
Mostly used with engines 2.0 HP and Higher.
About the Engine:
•Honda 35.8 cc Mini 4-Stroke OHC
•OHC engine reduces weight, noise, improves start ability and reduces oil consumption.
•The internal timing belt is maintenance free.
•Powerful, Easy starting, Fuel efficient
•Runs on regular gas (no mixing)
•Quiet - pleasing "low" tone
•EPA/CARB compliant
