Yep, that's what I've done.Don't forget that anytime you replace piston rings you have to follow break-in procedures again.
it might, needle only works up to 3/4 throttle, after that you're on the main jet
NOTE: changing the main may require finding a new setting for the needle height too
What? The big spring is for heat dispersion around the clutch cable sheath. The thinner spring is for the clutch engage assist. You definitely need the thin long spring...
Well I've changed the jet size to .68 mm and the bike runs much better. I've had to change two of my head studs from SBP because they were too short and I stripped the thread twice. When I opened up my head I noticed it had a lot of carbon build up considering I only ran it for about 25 miles after I did the head work. Maybe because of the oil I was using?
