I've fooled with many of these CNS carbs and they are all about air/fuel ratios.....while the c-clip will help you fine tune the carb, sounds like you are off pretty far. Float levels are another thing to check but again, unless you are spewing gas out of the overflow tube, probably not your biggest problem.Try taking the air cleaner off and run the motor. Chances are it will run much better. Now you can't or shouldn't be running around without an air cleaner so if that helps, get yourself a "known" number 70 jet(one marked with a 70). That should fix the problem. These jets from the factory are usually not marked and I've found them as big as a #80 jet. Way too big! I guess they are just drilling out any jet they have lying around and it can really cause tuning problems. Hope that helps. Oh, by the way, you should pop off the brass plug to access the fuel mixture screw. Start with the screw set at one full turn open.(screw it in the whole way till it stops and then turn open counterclockwise 1 turn)
