I had a problem last week with a clutch imploding. Everyone here on the forum helped me obtain the correct parts, and I started the repair. For some odd reason the clutch is so firmly attached ( spot welded?
) that I stripped my puller tool.I can't imagine that these clutches are so firmly attached that they could not come off with the amount of pressure I was using. Should I have used some heat to get it off, I am at a loss on what to do now. bairdco in this forum was kind enough to actually send me a puller and clutch assembly so I could get back on the road ( THANKS!! ) , Now I have the parts but a new puller isn't going to solve the problem. HELP !
Also I have obtained a parts motor from DAX, it had everything minus the head. I thought that I could just pull the head off my other motor use the secondary motor I have, but the piston is hitting the head. Are there different crank lengths? I would like to get motoring again but really need some help.
Thanks
Thanks
