Need For Steve
I've been a long-time lurker here on the forum, and I've finally whipped myself into the mood to start my own build! I have a basic plan, a bike, and an engine. The plan is to ultimately end up with a somewhat-decently functioning friction drive setup, and to use a bit less gas on trips that aren't time-dependent.
The bike is a Mongoose 26" DXR AL mountain bike. It's an 18-speed bike with a fairly decent suspension setup, and side-pull brakes. I'm not sure of the age, maybe 4-5 years? It doesn't need much to get going and I'm getting a good price on it.
It needs a rear inner-tube and possibly a new set of tires, as the ones on it show a bit of dry rot.
The motor is a Homelite SX-135 25cc weed eater motor, dated 08/95. Fuel lines and a new primer bulb will have it in good shape, then it's onto figuring out how to mount a peg. The real bear, I'm thinking, is going to be in figuring out a mounting system that'll work with the rear suspended fork. My first real idea is a sleeve mount on the bottom of the seat tube, with the motor held down onto the tire by spring tension.
I've got a bit to figure out, but it should be a nice little rig if I can do it right. I've even got my first real piece figured out; a thumb throttle that lived on my old MTB as a thumb shifter...
