See post #18 to view these two pix in a readable format. Thank you very much for ur assistance with this KCVale. Greatly appreciated. Ivan
Important Note; The SCR must be put in the right way. Positioned as shown on the layout, the side with writting on is facing UP. The SCR has been bent back to be lying flat against the board.
Ok, if u cant properly read the resistance values (in blue), they are; across the top, left to right; 16 ohm, 120 ohm, &220 ohm.
Next down, running along the right side of the SCR (as seen here); 390 ohm.
Next down, along bottom of SCR (as seen here); 1k.
Next down; 33 ohm.
The next down, & last is amongst the timing caps; 760 ohm.
The small caps near the 760 ohm are the 35V Tantalum's & from left to right are;
0.47uf (on a jumper to ground)
4.7uf (next to 760 ohm resistor). Both cap & resistor go directly to ground;
0.47uf (on jumper to ground):
The + marked leg of the 3 tantalum caps must go to ground (or jumper for the 0.47uf's).
Hope this helps.
Ok, hand drawn layout & schematic for the stock aftermarket CDI. If u click on them u'll get a full screen photobucket pic. They arent in a seperate album so u can also check out my switchable #39/#36 modified marshall amp clone (as used by Slash for rehersals (#39) & recording (#36) of Appetite For Destruction) in various states of construction. Wicked sounding amp, but thats another story.
U might notice 2 differences between the layout & schematic.
(1); the layout shows a 16 ohm resistor where the schematic shows a 15 & a 1 ohm in series. The jag uses 5% carbon film resistors & a 16 ohm isnt available in this type. I use 1% tolerance metal film resistors & a 16 ohm is available in this type. Use the 1% metal film type, 1/2 watt. They are better quality & closer tolerance, & cost a couple of cents more than the carbon film type.
(2); The layout shows two 0.47uf charge caps while the schematic shows one 1uf. Adds up to the same thing.
I'll get the complete component list up after I knock off this arvo. If anyone has any construction questions dont hesitate to ask. Till later this arvo, cheers
Next down; 33 ohm.
Hope this helps.
