Hey guys. Been having about every issue you could have with this motor kit, but she's purring now.
She's got about 100 miles on her now, and I had to get a new gas tank (tightened the first one down too much, got a small crack, tried brazing it, and I guess I didn't add enough material), but I have a piece of tire tube between it and the frame, and that really seems to help with the vibration and it helps the tank stay put without being tightened down so much.
Got a new exhaust because the end cap on my stock exhaust fell off and got run over. Now I will say that with the open exhaust, the bike ran pretty sloppy at low speeds, but when I open that throttle, she would GO. I weigh about 145, and I clocked 37 mph on a 44 tooth sprocket, with acceleration being very quick. Anyway, put the new exhaust on, and while it takes a minute to get up to speed, and it's a little slower than running open exhaust, but the motor is loving the lower speeds now. Which is good, because there aren't a whole lot of places around here that I'm riding WOP.
Also got my chain tensioner set up right. Used a 10" arched piece of steel, and attached it with U bolts. I took the white wheel off of the stock tensioner, and put a good skateboard bearing (I'm going to try and make a skateboard wheel into the tensioner wheel like I've seen, I would think that would work awesome) in it, and got a longer bolt, with some extra nuts and washers. Gotta say that I love this style tensioner, I feel very confident in the fact I'll almost never have to mess with it.
Anyway, next on the list is getting a good disc brake set up on my front wheel. Any suggestions? Also, going to take everything apart at some point soon and powder coat everything. I had a really good rattle can paint job on this thing, but it got all torn to **** with the carb issues I had leaked fuel all over everything.
Any feedback is appreciated.
