silverbear
The Boy Who Never Grew Up
Before anything else, welcome to the forum. This has been a good way for you to get your feet wet in this motor bike craziness. A suggestion for the petcock problem is to use an in line fuel shutoff and at the gas tank use a brass elbow type of fitting so that where you attach the fuel line it is right up against the base of the tank.
Regarding the use of a sidewall generator for lights, it is true that at speed you will burn out incandescent bulbs. But not LED lamps as they are more tolerant of a wider range in voltage. I use an older 6 volt version of the sidewall generator (lots of them used on ebay) and have used flashlight units intended for 3 AAA batteries which would come to an intended 4.5 volts. At speed I'd guess the generator puts out 8 or 9 volts, yet I have never burned out an LED unit. They also use less juice than incandescent.
You're doing well! You might want to reconsider selling your bike while you are building the other one. Do you really want to do without? And you know two bikes really are better than one. You can take a friend riding or have a backup bike for when your primary is out of commission for upgrade or repair. They get lonely all by themselves...
SB
SB
