question about battery overload?
deacon
minor bike philosopher
I have two 36v motors I want to run at the same time from one battery source. They are not matched motors, so I have two controllers and two throttles, but I am going to attach them to the same SLA battery pack.
Has anyone done this and if so what was the result.
well since no one seemed to know in time. I just put different sized fuses on each circuit and I'm going to try it tomorrow.
i didnt know deacon, will be interesting to hear how it worked out on your electric bicycle
my back might be good enough to test it this week. I got a pocket full of fuses so I shouldn't blow anything but I might melt the cables to the battery if it pulls the combined amps through them.
Sounds like dangerous territory. The batteries themselves are only designed for a certain amount of amp flow discharge, not just the cables that you worry about. The combined fuse rating should be less than the battery spec max load, imo.
Methinks it will drain the battery very rapidly.
SLA can handle a rapid discharge. Specs?
That was my other fear. But i think i will use both motors at the same time only on monster hills. The thing about electric, that I like and hate, is it only flows when you tell it to. I don't have to use both circuits at the same time. What happens when I do is anyone's guess. But I promise I will let you know sometime this week.
Frankly I'm not worried about some last year's batteries, I'm worried about the controllers and motors.
Frankly I'm not worried about some last year's batteries, I'm worried about the controllers and motors. oh yeah one motor is 800 watts one is 350 watts.
Its ok you can do it. That's not enough watts to worry about. Of course the more juice you use the faster they go dead that's all. I wouldn't worry about it unless you were using 2000w or more. You should get about 10 batteries and run them both at 120v just to see what happen(^)
Ok. If you draw too many amps you will get more voltage sag which will result in lower speed and one or both controllers shutting off because they will think battery is too low time to shut off.
That could explain the extremely poor performance of the low watt hub motor I was trying to use with the hight watt friction drive. I had to give up on it just too much trouble for the small increase in power.
