trackfodder
I just completed the fork I turned backward and put the Honda 50 spring links on, but it doesn't look old enough. My thinking now is to copy the Pierce fork. It was on a four about 1910. All it takes is 2 balloon forks with a coil spring on the front stem working against a top stem plate on the rear fork similiar to a Schwinn springer. A heavy bolt working up and down through the plate with a bushing with a head on it and a rubber cookie to rebound against. A domed cap on top would keep fingers out of trouble. So far I know my Norton outer valve springs are a force fit on the 1" stem. I will have to get the spring and do some calculations as to where to put the axle and front fork so the action is right. Stay tuned. Trackfodder
An O-ring is my rebound cushion at present. It will take some contriving to put a fender on it. I don't like the short fork steering tube, but I will probably just recover it and do a whole frame from scratch as soon as I decide on a motor. The rear fork is a 24" and I don't have any others, so I'm stuck with it. The fork is copied from a PIERCE, not a Pearce Cheers to all,
The HT is no longer a candidate, but I have a 6ft. version of the Atlas Van Lines unlimited hydro with the Allyson V-12 that has a backward turning Quadra 2.2ci. with 2.2hp and a rope starter that was WAY inadequate for the boat. Been waiting for a butt-kickin' chainsaw to come along I could upgear with Gilmer pulleys and belt. I don't want to get started with 1/4 scale boats. Anyhow, I can put the necessary sprocketing in the front shaft hanger and use that engine Also there is a Kawasaki snow blower mill that I stuck a weed eater centrifugal clutch on that also has a rope starter. It was too rpm limited for the 1/4 scale Crackerbox boat. About 32 cc. At least it's cute.
