trackfodder
I just completed the fork I turned backward and put the Honda 50 spring links on, but it doesn't look old enough. My thinking now is to copy the Pierce fork. It was on a four about 1910. All it takes is 2 balloon forks with a coil spring on the front stem working against a top stem plate on the rear fork similiar to a Schwinn springer. A heavy bolt working up and down through the plate with a bushing with a head on it and a rubber cookie to rebound against. A domed cap on top would keep fingers out of trouble. So far I know my Norton outer valve springs are a force fit on the 1" stem. I will have to get the spring and do some calculations as to where to put the axle and front fork so the action is right. Stay tuned. Trackfodder
