I've just assembled my motor and tried taking it out for a test run. You can probably guess what happened since I'm here... Anyway I mixed it with a 16:1 gas to oil fuel ratio, tested for a spark by spinning the rear wheel and touching the sparkplug to the head with no luck. I'm buying a OHM meter tomorrow to see if its the Magneto or sparkplug, but also on the test run the clutch cable seemed to get messed up, the lever on the handle wont retract even after I tried to fix it by pulling it tight I still have the same problem with it. So it created an unresponsive clutch due to the unresponsive clutch cable. The twist throttle wont retract in its original position as well, I'm thinking that I need to lube it ? Anyone have any suggestions ? These are just the problems I've experienced today...Every step to building this bike has been a nightmare, everything that was supposed to be one step took 20 substeps.
