motor started hissing last night (and still does when I can get it started), pressing on the gear cover will silence it until you release it. I figured it was the small bevel gear screw again (and it very well could be because it still does it when it does start). Then this morning on my way to work it lost power, kicked back in, and then conked out one final time and I had to pedal the rest of the way to work (being sweaty and working in a freezer for 8 hours isn't exactly ideal). It's acting really really rich too. Putting the choke on wont let it start, but it will start if I dont touch the throttle, choke off. giving it ANYTHING past slight idle it will bog down and lose all power (essentially the same effect you get by holding the kill switch while moving). And yes, the fuel valve is open, I've done that silly mistake twice already, I wont do it a thrid
I figured it was a crank seal but I'm unsure now. I havent taken it apart yet and I'm hoping another member may have experienced this. Being that I work tomorrow morning I dont exactly have the time to take it apart completely. So if anyone has any ideas, I'd like to attack the suspected problem head on.
