Hi my bike was running good for about the first hundred miles.... Then it just wouldnt go as fast and then it would just idle and not even go when i tried. I got a replacement nt carb and it would run with it but only like 5-7 mph and then it would die. So I figured Id try a speed carb and the same thing is happening I have to play with the choke to get it started and then hold the clutch in immediatly otherwise it wont run. Even when I go 5-7 mph I have to hold the clutch in a little otherwise it will die. Whats the problem?!?!? When I first got it I was doing 30mph no problem.
LINK TO THE CARB I JUST PUT ON
http://www.ebay.com/itm/48cc-gas-bi...prg=1006&rk=1&sd=190815404821&#ht_3120wt_1018
