first off left me start off by saying:
I AM NOT TRYING TO SUPERCHARGE A 2 STROKE
PLEASE READ EVERYTHING BEFORE YOU COMMENT
my bike is currently powered by a honda gx35 35cc 4 stroke.
these engines are notorious for running rich, and i also have been encountering this problem.
I also live at about 4500 ft above sea level so the air is fairly thin up here.
i had an idea the other day and this is what i have.
i had a electric motor from a vacuum cleaner. i took the fan wheel and housing
i got the idea of turning this into a belt driven supercharger for the honda.
my plan is to make a wheel about the size of the fly wheel and run a belt from the flywheel to a wheel that drives the fan wheel. the fan wheel is very light, and made of aluminum. i also plan of machining some of the extra material from the flywheel to help offset the power loss by driving the fan wheel. the wheel on the engine will be about 4-5x larger then the wheel on the fan, so the fan will run about 5 times faster then the rpm of the engine.
@7000 rpms the fan will be at around 35,000 rpm.
i have installed an air filter on the intake of the fan housing and i will fabricate an output tube that will be routed to where the filter on the carb was.
i have been helping out at a machine shop so ill be able to machine small parts, as well as a pulley wheel to attach to the flywheel.
ill also make a bracket to hold it, with a 90 elbow to go into the carb
now from what i have read on the internet, and based on my understanding..is there any reason that this wont work?
any critics have any comments?
i dont see why this wouldnt work. it seems like it will work.
i understand alot of fine tuning will come with this..and i am not expecting it to work right away, and i plan on trying to come up with dyno tests after each improvement..
comments?
![](/proxy.php?image=http%3A%2F%2Fi39.tinypic.com%2F2zya0oy.jpg&hash=4596fb49e39c2cee1ec2ff2323df7658)
![](/proxy.php?image=http%3A%2F%2Fi40.tinypic.com%2F9u2k1w.jpg&hash=fb89b47aebed0c4b98c8fe395408eb1e)
![](/proxy.php?image=http%3A%2F%2Fi40.tinypic.com%2Fjjljjs.jpg&hash=7025c4f3f2b0d7c92da92c6ee9ea9b93)
![](/proxy.php?image=http%3A%2F%2Fi44.tinypic.com%2F334u7on.jpg&hash=2682e67178c27abf247712f933ba9e1a)
![](/proxy.php?image=http%3A%2F%2Fi39.tinypic.com%2F4i0ygm.jpg&hash=2c8ca43803c71e52df703a1e548a51c5)
comments?
