my 2006 rocky mountain element.
this build is totaly different from using the china kits, and the shifter kits, this was completely DIY. motor mounts to figuring out how to shift. i choose a honda gx35 mated to a pocket bike 5:1 reduction trans. i grinded down the output shaft to 3/8 and cut in a key slot. next, i bought a 9t 410 sprocket with a key slot and taped for allen keys. the pocket bike trans sprockets are only avail in 12 and 10t, the 10t's from DAX being no heat treated stamped out of tin foil, were useless i went through one in a week. the 9t powers the fromt sprocket sized 48T. the main difference between this bike and the shift kits, is the fact that i have a reversing output shaft trans, so i had to mount the engine air intake forward, backwards from the kits. this allowed me to go directly to the from sprocket only using 2 chains, but to acheive enough reduction i have to reduce in my bicycle gears. not a big prob. the 48t is conected to a 24t and the 24t powers 34-11t 9 speed cassette. i plan to reinstal my front derailer so i will have 36 and 24t in the front. this would be optimal for riding it like a bicycle which is still very easy since this entire build weights very little i would guess less then 50lbs dry. the gas tank is a go-ped 1.5 liter mounted on a front rack. rack 20$ tank 35-ebay. this is a two line carb engine so this tank works well. the nice thing about the gx35 is it can suck gas into it so i could literaly put the gas tank anywhere. the handle bars are fly racing for a pit bicycle. forget which ones i found ones with the goemetry i liked. the air cleaner is for a pocket bike carb slightly motified to fit the gx35. pull start. at the moment it has a very short pipe, its very loud. i am planning on routing the exhaust around the bottom to the other side and over the trans and come out under the seat, and ill get a silencer for it, to make the hippies happy. people always cover their ears when i go by but i think its good cuz loud pipes save lives. most of the parts i got from SBP and staton.
ill post a video of riding this thing as soon as i can
this thing does 25 up a hill, easily 40 on a downhill and goes 30 on a flat no prob. im sure it will be faster after i finish my exhaust. and im no light fella. i weigh 225 lbs. lol.
im thinking of adding a 38t for the first gear. im thinking of setting it up so ill have a super low first for off road and steep steep hills and wheelies. lol.
but on flat or at a light the 34t is great for starting at the moment. there available on ebay, and since im running a cassette, ill just simple toss a lower gear. so ill still have my 11t. and ill have 38-11t. thats a huge range.
Right now, your first gear is 37.78:1 and 9th gear is 12.22:1. Eighth gear is 14.44:1, 7th gear is 16.66:1. Changing to 38t lowers First gear to 42.22:1, which is a good thing. On my 8-speed shift kit, First gear is 46.36:1, Second is 38.18:1, 7th is 17.73:1 and final drive is 15:1. I rarely use First, as 38.18 is more than enough for steep hills. My bike, all my gear and I prolly weigh 310lbs. You'll love the 38t, especially when your original First gear was 34:1.
