Like this then?Hi Toadmund, if there is only 1 terminal or wire on the coil (besides the plug lead), then the earth connection (black magneto wire) goes to the iron core that u ask about, as well as the CDI u r using. If the coil has 2 terminals or leads other than the plug lead, 1 will be the earth, tho it probably would still be internally connected to the iron core. Cheers
	Hmmm, this is becoming a lonely thread.
Anyway, I finally finished my CDI unit, the simpler one with the retard function.
And I just got my Ignition Coil in the mail yesterday, it cost me 10 bux on fleebay.
Now I just got to check it over again for the 'nth' or 'eth' time, then I'll put it on my bike.
Now, I'll have to make the jag clone sometime soon.
Here are some pics:
Is yours a straight or slant plug? I have no room either, if I want to remove the head, or head and cylinder, the motor has to mostly come off, but I have no issues with my plug boot.
I would tell you about the plug wire but I am not about to find out how removable it is unless I absolutely have to, just in case it alters the structural integrity of the unit.
It may fall apart just as well on its own anyway!
It doesn't move,..... well it did, but I tightened it back up again, so I assume it screws out just like the stock one.
I saw the same one up for bid if you want the link.
