Jesse_James
When I first run my bike I get good performance for the first 10 seconds at full throttle but then I start to lose power afterwards sometimes even stalling out (while still on full throttle) why is this?
I also notice when coming to a stop (red light stop sign)and pulling the clutch in is when the engine goes into a high rpm I mean really high rpm so I always have to use the kill switch to stop.
no high octane won't hurt but why when 87 is all it needs. Well check for air leaks is the high Idle problem. Start engine get a can of carb cleaner and spray around carb intake if idle raises there's you leak fix them and she will run better. The carb intake is the biggest spot for leaks and both ends check them.
Before you look for air leaks, make sure your throttle cable isn't too tight.
Your not getting enough fuel, you may have to adjust your float, or you have some dirt in there, possibly partially clogging your jet. When your choke lever is up you are partially blocking air intake which makes the engine suck in more fuel than air.I sprayed some carb cleaner into the carb and it worked for about 10 seconds then stalled. Then I used the cleaner again and after multiple times of doing that process it worked. I also pushed the choke lever upwards and it worked fine which confuses me because I thought the choke lever was supposed to be down for normal operation.
I am still new to this stuff. I am clueless on how to adjust the throttle cable from the top of the carb and I don't even know if I fit the needle, the spring, and the big round plastic piece into the carb the correct way when I screwed it back together after spraying carb cleaner into the carb.
