Many of us have had to rethread the cylinder holes or studs for the exhaust. Here's my nightmare.
Originally I rethreaded both holes to 7mm and that only lasted a little while. The left hole is now an 8mm. The right hole was good until I went to tighten them both back down and there she goes too...stripped. So I tore it apart again to turn it into an 8mm also. Something went wrong and ended up with the crater you see here.
I've searched the forum for repair options and I went with the heli coil repair. I bought the 3/8 16 repair kit and drilled the hole out with a 5/16 drill according to this chart http://www.newmantools.com/tapdrill.htm
Oh I must mention the reason I went with that size is because I was rethreading and tried to hurry the process with a drill. I ended up boring it out completely.
What I'm left with is a huge hole that I believe has ruined my cylinder. Is there any room for repair or should I cut my loss and get a new one?
