Walmart FatBikes
The last bike I built back rim is 3.5 inches wide and took some real work to get it right... Spacers on hub adapter, special jackshaft, cut chain stays to make tire clearance.... It was worth all the work tho
I think that bike would be a great build and fun to ride. 99cc four stroke for sure.
I wouldn't recommend a friciton drive on them... The tires are quite rough (like offroad or MBK= Mountain Bike tires).
Dunno Digit, well better then knobies. Just conversation and do see your point but don't think it would be to bad.
Looking at the picture carefully, a chain or belt would not be real hard.
One real down side is, could replacement tires and tubes be found? I still really wanna build one. That bike be just perfectly fugly, snork.
I'm thinking a staton crank shift kit so you got three speeds at least. But the coaster brake is killing me! What about brakes? Wait,cyclesus.com makes wide brakes right? Off I go!
It does look like a 'dozer compared to other bikes.
I think a sprocket kit will work on them; there's not much clearance, but there is some, the frame is rigid, and the tires only go 1/2in wider outside of the rims.
After a few simple mods, this would make an absolutly incredible motorized bicycle. I'm sure with a bit of redneck thinking a person could make up a wide multi-speed hub, and then if a person took a set of those removable bmx brake bosses, and then you would just need some metric nuts welded onto the seatstay's for the bosses to thread into. And I'm guessing then just some cheap v brakes would be able to be bolted on.
I've put a lot of thought into this ha ha
Ccd
Thanks Draco. But here's the kicker. If it has a pedal chain,and it most certainly does,then just run a crank shift kit. You don't have to buy statons. It would be the easiest. Make your own. I probably will,since over 200 is more than I care to spend on something that WILL need to be adjusted.
Here is an idea with this bike...
attachment.php
If you're making it like that, you'll have to add the passenger foot pegs :)
On the other hand, I'd probably prefer a saddle with a little of damping, so you could mount the back of the saddle to a shock or spring system
Screw it...I'm going to buy one. I've been itching to tinker and build something again. I feel this will be a challenge, and if completed successfully, will be one **** of a conversation starter!!!!!
Just couldn't resist, had to get me a Red Beast... For now I will just ride as a regular bike, but I may just have to motorize it later. :D
