so i just finished up with the break in period, decided to take it for a good haul.
checked everything b4 i left.
it made it to the final destination just fine(with the exception of the kickstand rattling loose)
when i went to leave about 4 hrs later, i had this weird popping noise coming out of the front end of the engine. sounds like a balloon popping. pretty much every time it sparked.
i did make it home with out too much hassle. but it died about half way and wouldn't fire:s ...
had to walk up the bridge. and decided to try again on the way down the bridge(large bridge over a river).... took a bit but did fire up.. again with the popping.
had to keep revving the engine to keep it running at idle, and once i let it settle for a coast the engine revved down and just quite.
Ive checked the plug cable, its solid.
i pulled the head and found that the upper gasket was cracked. replaced that.
checked that all the casing bolts were tight.
and checked the plug, and spark while i was at it.
when for a test ride and had to get up to about 15km/h to start it...
again with the popping noise. its not a compression popping... as i said above, its like a balloon popping.
anyone have any ideas??
