Yes, I did.It's hard to say...different sized parts? Did you re-install everything exactly as you removed it?
Does the clutch work normally otherwise?
You can still use the new ones, just carefully sand them thin enough to fit.I did change clutch pads that was the problem they were thicker and went back with the thinner one's,dam you nailed that right on.
