10 tooth on front 54 on back
yellowbeard
got my engine on my trike, 5hp B&S with a 10 tooth cent. clutch and a 54 tooth on the rear axel. put it up on some jack stands seems to work good. Not sure of the speed though. Will post some pics in a little while. Joe
Well great!
...there's speed calculators out there someplace... feed in your data and it will tell you what it will do in advance... GPS probably the EZ way, though.
Have fun!
rc
here's some pics.
I still like alittle work to finish it up, Kill switch, throttle cable and brakes. And a whole lot of cleaning to make it shine. If the weather clears, I will get it out for a test run, and see how she runs. Joe
doh, just saw your other thread, good you found the calc already. A couple of ideas for rear brakes, Deacon and a couple others used a bar going across, with a caliper for each rear tire:
or there's the band brake route too:
to go with a coaster brake you'd need a coaster hub driving the non-motorized tire I think. Depends on your setup, but a front brake is always good to have too :)
That is a very cool and fast looking build! Kudos!
I would suggest a live axle and disc setup in the rear with a disc in front as well.
You're gonna need good brakes...
:O
fabbed a chain guard
Here's a few pics of my chain guard that I fabbed up today. Got to protect the rider.
