graydog8josh
I have a schwinn High timber 26" bike with:
26 x 1.95 semi slicks
415 chain with 41t sprocket and rag joint
thatsdax premium f80 engine 66cc(60 something cc)
upgraded chain tensioner with a 10t sprocket off ebay
nt carb, stock jet size #70, clip is in center position
low profile SBP air filter
the intake i modified with a 90 deg copper pipe jb welded to make the motor fit in the frame
ngk iridium bpr7hix plug SBP
BGF expansion chamber
I have the tank double bungeed to a rear rack due to issues with cable routing.
Ive seen reports of speeds ~ 35-40 mph but i can only squeeze on 28 on the flats and the engine will get me to 33mph top downhill screaming bloody murder.
1: What can I do to hit my targeted high 30 speed goal?
2:will a #41 chain increase my top speed?
3: will a 24 x 1.75 tire and 24" rim increase my top speed?
4: will changing the carb jetting increase my top speed?
5: how about taking the dremel to the intake pipe?
As is, it runs rather smoothly, it just lacks that top end I feel would make me comfortable in town. Not trying to break any land speed records, just want 35 mph WOT on flats.
oh yeah, and im running 91 octane pump gas 20:1 mix.
I weigh 190lbs.
I weigh 190lbs.
