TRAX
Looks like you truley do have a year for Thanks Giving and especially to God, thanks! for not leaving God out of it.
Bike looks good and I really like the forks.
Thanks the forks took some doing I had to cut the cup that holds the bearings off another frame and invert it so I could use the stock fork with the springer.the old one had a little bit longer stear tube.
I have 46 years I'me truley thankful for, this one maybe a bit more than others.
Glad to hear how good you're doing. Hope you have a good Thanksgiving today. May the Good Lord continue to bless you & Lisa. Anxious to see you both here in August at the rally.
Jay
Jay, Thanks Giving was great hope yours was too. Lisa says hello Thanks for the well wishes, It will be good to see you at the rally.
Happy Thanksgiving, bike looks good. Your a positive example of being down but climbing back out. Lots of prayers for you and Lisa Peace Ray
Thanks the prayers and kind words Ray, had a great thanks giving. hope yours was too.
Keep praising God and he will keep healing you.
Even if he decides to stop healing me I'll Praise him..
Have a question about this picture.
Your copper exhaust, what way did you put it all together and did you do it with your last build the same way? How well does it hold up to the heat and vibration?
Check my next post it will have the details on the exhaust. short answer is it held up well after 800 miles before the accident and it was the same setup. the long flex pipe is soldered to a straight pipe and then to the horn end. at the engine the copper goes over a short section of the stock pipe and is held on with a silicone sleeve and clamps
Trax: Had a friend that had a rod in his femor when it was removed he had it drilled and he now uses it as a stainless steel piece pipe.
Putting that thing on your bike seems like a great idea!
I still have my rod, I don't smoke but you got me thinking about what I might do with it if I ever have it out. I'm Going to post lost of updates soon see if you can spot the plate from my leg in the pictures......
