locell
29 inch wheel sets are getting pretty popular, I've seen a few build on here with the Genesis Onyx 29" Cruiser, and the 29" Thruster "fixie".
These come with 29" Tubes with a schrader valve and wheels with a larger hole to match the schrader valve. If you get hole in a tube that you cant patch, its hard to find a 29" tube with a schrader valve, they are all presta.
Solution, just use a 26" tube. It works, just a lil bit of a different install. I put the tire on the rim with one bead, put the valve through the rim, then stuffed and stretched the tube onto the rim, then finished putting the tire on. You just cant find a schrader valve 29" tube.
