mystery scooter engine chain drive
deskman
42
california
hello!
first time builder here...tonight I picked up a free engine from a buddy of mine, a small sticker on the side says 43cc scooter engine.
the engine has a centrifugal clutch and is pull start...also the air intake is missing a piece i think
as you can see from the pictures its very wide, making the shaft extend far past where the sprocket will be placed. to make it come close to aligning i'd have to be placed verrrrry far off center.
http://i.imgur.com/ikdyw.jpg
http://i.imgur.com/AAZDO.jpg
http://i.imgur.com/uRjME.jpg
i'll be using a mountain bike, it fits fine aside from the width.
one of my priorities with this project is that i'll be able to pedal so i need clearance.
so questions,
a. is it worth it to use this engine? im a first time builder, am i getting in over my head?
b. will this engine be faster than a 66cc china girl? more reliable? i'm looking for the ability to tackle some hills as well
c. would a rear mount be a more elegant solution?
deskman
42
california
since its got a centrifugal clutch does that mean if i do a friction drive there will be no resistance if i were to pedal with the engine off?
Ludwig II
5,071
783
UK
There will probably be transmission drag if you pedal, how much, I don't know. The reason for the engine being wide is you have what I think is a reduction gearbox fitted to bring the revs down so you only need 1 stage of reduction after it to drive the back wheel.
tooljunkie
663
5
16
Manitoba,Canada
looks like a good candidate for a jackshaft and a rear mount.there would be more fabrication compared to an engine kit.
something you need to know is the ratio in the gearbox.
wayne z
1,743
5
38
louisiana
That engine has a 5:1 reversing gearbox. The output shaft turns opposite of the engine rotation. It also has an electric starter behind the pull starter. This is another reason the engine is so wide.
A buddy of mine built a rack mount with one of these, with the engine running a freewheel sprocket on the pedal crank, and he used the derailer gears. Runs great,but It is not as powerful as the 66cc HT engines.
pocdragon
128
RI
MRJOHN
73
2
8
54
usa
hello!
so questions,
i have one 45 to 50 mph
motorMount http://www.curtisparts.com/web_gas/49cc_Pocketbike_motorMount.htm
http://www.bikeberry.com/engine-kit-parts/4-stroke-gas-engine-parts/heavy-duty-4-stroke-mount-plate.html
GEAR BOX
http://www.tsunamibike.com/catalog/item/5535391/7025488.htm
sprocket and chain ,gear box sprocket
http://thatsdax.com/ENGINE_KIT_PARTS_PAGE_2.html
iave a look at may bikehttp://motorbicycling.com/showthread.php?t=40606
