Here are the specs on my engine 66cc
ported 2mm higher 2mm wider ex
2mm lower 2mm wider in
4mm deep by 6 wide boost ports in between the transfers and intake, going as high as the transfers
piston skirt cut to match the intake
no base gasket
head has bin lathed to remove the flat spot in the combustion chamber to allow the piston to come up farther (acting as a stroker crank and real swish
port mached everthing
stock carb
with a 44t im getting a 100% Honest gps 57-61 kph (the rpms stay the same but the speed changes from 57-61 kph at wot I think up hill down hill and wind have something to do with this
I bought a 36t of ebay in hopes it would make me be able to start it with less effort or in the wet, the conpression is at 197psi with not base gasket and i head has bin modded to let the piston come up farther with out thouching the head.
I scard that my engine won't have the balls to get the bike moving with a 36 form a dead stop tho.
my 0-5% speed power is nothing,would not make it up a hill and my 5-95% power is twice of my friends stock HT
one more thing i want to know is im doing appox 37mph with a 44 on 26s
what would be my rpm ?
and apox what will be my top speed with a 36t at my max rpm
sorry for so many qustions and blabbing
no base gasket
stock carb
