Right now I'm running with the stock junk CNS carb that came with my kit . I've done everything possible to make this thing run right and its just never ran to its potential . There are no mixture adjustments on the CNS so its impossible to do anything but adjust your idle . My motor came from the factory with a head that had a cross threaded spark plug and sucks air so it has to be replaced . While I have it tore down to fix that I want to replace the carb and intake to something that's going to give me more option to adjust it and better performance . I've narrowed it down to either the RT or the NT carbs with a shorter straight intake rather than the offset intake that came stock with the kit . I know I'll probably get a few different opinions on this but that can be a good thing . Which is the better carb and will I need to order a new throttle cable for it ?
I guess I should have mentioned .This is a 66/80 Grubee SkyHawk
