As dragray said that motor is a 50ccI saw this in a kit at boygofast yesterday, and wondering if the wider intake port here is any good?
Do you think this will be a future trend, and we'll see the kits change to this?
that's how my 49 cc is...no intake manifold.
the carb is bolted right to the cylinder with some long studs with nuts on the ends.
this carb is totally different than the standard nt carb, and it's a 13 mm.
this carb can be found on china made 4 quads, pit bikes and pocket bikes.
the carb itself works great but i think it's a tad too small. it's also a pita to get the carb off to re-jet, adjust the float, etc.
on the up side, this set up is excellent for 20" frames (which is what mine is) because the lack of an intake manifold, frees up room for clearance between the air filter and the seat post tube.
Well then I wonder WHAT the picture is then? I don't think it looks like the "sleve" carb, but I could be wrong. Perhaps it's changed since you got yours.
Also the intake studs- are they wider spaced on yours? Is it the 40 mm spacing?
I'm wondering if this will be the trend of the future.
maurtis- I read your thread- interesting- but you never reported how it ran!
I would think the bigger intake and matched port would do quite a lot. Is it the newer 66 Speed carb?
Sounds like you are wanting better carburetion?
So yours has the wider spacing but still the smaller motor mounts?
