I see Kings custom sprockets sells hub mounted freewheels/sprockets, and top hat adapter that would allow to mount a disc brake. Does anyone use this type of setup and if so do you like and recommend it?
The only downside to using a hub mounted sprocket that I can think of is that it doesn't allow for adjusting the chain to line up between the wheel and motor sprockets like a hub/sprocket adapter can. Mounting the sprocket directly to the hub seems like a good idea but good braking options are limited.
