how many and what size batteries were the lights designed to run on originally, and how long have you been running these lights with no fuses?
curious. when i put a 6volt light on the white wire the bike ran great but i had to make sure the light was off for the motor to start. you having the same issue?
I'm not a fan of the whole "cram as many LEDs into a flashlight as you can" mentality. I've got a .25 watt Cree LED flashlight (It's an aluminium high-powered flashlight by Coleman). It's one single extremely bright LED, and it has a proper LED driver which is more efficient and can act as a regulator. The lights with a ton of LEDs usually just have a resistor for each LED, which hogs power.
I'm not either, I linked both the 50-pack and the CREE LED, but I'll probably use the CREE LED for that exact reason! I think .35 watts should be fine off the magneto, as long as it runs half-decent-- I probably won't be going top-speed at night anyway. =) five bucks for a driver and high-power LED is great if you already have a good housing.
Bigbutterbean.
I don't think the 50 led that I saw pulled from 4 AA batteries. I blew one that had three batteries when I was experimenting with different lights. The 76 led light that I got on e-bay has given me no problems but it uses 4 AA batteries which = 6 volts.
