How about the controller? Is this a separate piece of equipment you'll need?
They've a selection of different motor types, up to and including conversion kits for scooters, even cars - most require a separate controller, but the 'Magic Pie' does not as it's built into the hub motor itself... so it depends on which motor you're looking at.
How about the size of the battery?
Again, depends on which motor you're thinking of - but generally speaking it's safe to say you'll want the one with the greatest AH (amp hours) you can afford as that's your reserve/range, the size of your fuel tank so to speak. If you don't mind a little (very little) bit of fabrication, you can get somewhat better reserve for slightly less of an investment by getting your batteries elsewhere - you'll just need to make your own mount/case to put 'em in like panniers for example... I've had great results with these;
http://www.pingbattery.com/servlet/StoreFront
http://stores.ebay.com/PingBattery
I'm electrically challenged and don't know what size battery I need. There should be a chart or something to describe in laymens terms the operating perameters of each battery.
It gets a little tricky as much depends on which motor you choose, it's voltage & amp draw and weight, terrain & usage ofc... but as an example I've a 48v 1000w 12a 'Magic Pie' with a 48v 15ah LiFePO4 pack (Ping)...
v = volts
w = watts
a = amps
ah = amp hours (example: 15ah = 15 amps for one hour or 1 amp for 15 hours etc.)
At maximum draw my motor uses about 12a and does a hair over 25mph and I've a 15ah pack so;
15ah / 12a = 1.25hrs x 25mph = 31.25mi
...the math says I should be able to ride for 1.25 hours at it's max 12a draw which at 25mph = 31.25 miles. During testing on hilly terrain in breezy conditions, maximum speed all the time and without any pedal assist I achieved a touch over 27 miles actual - which confirms the math... which I've never trusted on it's own as math confuses & terrifies me lol, but if I had level ground in no wind conditions to test with I'm pretty sure I'd have gotten the 30 some miles I should have.
Also, am I correct in assuming that you need to go somewhere else to find a battery charger?
No, both Golden Motor, PingBattery & most other vendors supply a basic charger with their batteries - but they are very basic "trickle" chargers (mine is a 2a) so if you wish less recharge time, you may want to upgrade.
I don't see one on their website. How do I know what kind of battery charger is compatable with the configuration of their batteries?
The ones they include are matched to the battery type - but it's just a matter of knowing the voltage and type of batteries in the pack, the chargers offered are usually clearly labeled what they're for. It gets slightly more complicated with custom DIY packs, but the standard 24, 36 & 48v setups are pretty much "plug n'play"
BTW: some additional details just to confu... erm... clarify lol - I didn't get mine from Golden Motor direct, so I dunno about their specifics. My motor is a 'Magic Pie II' and they've since developed and are now offering the 'Magic Pie III' which
might have slightly different preformance parameters. As I didn't get my batteries from Golden Motor, I can't attest to their specifications *shrug* Our
Motorized Electric Bicycles section has more info, my MPII build and a coupla MPIII builds in progress if yer curious
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
