Hi everybody. I just wanted to share with you all some of the details about the experimenting I've been doing. Over the last couple of days, I've been testing a modified cylinder head. The engine was a GT-5 skyhawk engine which had a number of problems affecting the power output of the engine. First, the transfer ports were very restricted, so I carved/beveled channels in the piston crown. That didn't quite seem enough, so I put an additional gasket on the bottom of the jug. I also "decked" the jug, taking about 1/16" inch off the top of the jug. Then I put the head in the lathe and faced some material off, and created a squish band. I am very happy with this low cost modification. With proper fuel quantity, detonation is kept at bay, and the power increase was very noticeable! The nice thing about taking the material off the top of the jug is that I can lower the compression by simply adding another gasket between the jug and head. Now I am about to experiment with the older style slant head, and I'll report how that goes. After all this experimenting, I will be able to make a brand new head, machined from solid round stock. I am torn however; do I work within the limitations imposed by the original studs, or should I design the head to be used with longer studs?Since I have ample room above the engine, I am leaning on getting longer studs, so I don't have to recess the retaining nuts deep in a counterbore. I know I won't be able to sell heads for less, or even the same price as Pirate cycles, but I think I can make them reasonably priced. The head design will be round instead of square. I'll cut the cooling grooves in the lathe which will be very fast. I'll use a long reach spark plug as well. I think I'll machine the spark plug hole directly above the cylinder, so It won't be a slant head. Well, cross your fingers, hopefully it works out. I will probably have something to test in a few weeks. I was thinking also about selling some decked jugs, so other people without a machine shop will be able to deal with the problems I had to address with my GT-5 engine. The modified heads could also be sold for a very low cost, however, I'm still working on the best combustion chamber contours. Sorry about the long winded text here. Let me know what you think.
-Fred
-Fred
