The pins on the piston face towards the intake port.I'm confused which way they should face, toward intake or exhuast?
or does it really matter? is it important?
I hope you know what Dave said too cause otherwise
you will break them.
Also the ring ends are angled so they only go one way.
Good luck!
Look on the top of the piston. On the same side as the pins there is an arrow that points across the piston towards the exhaust port. Cheers
On the crown (top), adjacent to inlet port. If ur all carboned up from running rich or 2 much oil in ur fuel u wont c it, its only lightly stamped in. If u've got healthy varnishing u should c it. Most all automotive pistons have this, indicating forward direction of travel when installed. If u havent got its the first I've heard of, but thats not 2 say anything. Cheers
