Jak - I don't have a site that has the formula, but I can explain, I think. There are quite a few ways to formulate a two stroke engine, I know it seems like if you limit the amount of time the charge can push the piston down it would also limit the power produced. The problem is that you also limit the time for the exhaust to blow down the pipe, thus limiting the amount of charge you can introduce into the chamber. Remember the piston is not pushing the charge out, it is the pulse from the expanding gasses. Also if you are using an expansion chamber you have to wait for the ram affect to return from the pipe, so you also want to let some of the charge escape down the pipe to be returned with the shock wave. There is another reason that the ports are manipulated and that is to restrict or enhance the amount of power, this engine is supposed to be at the two HP only to meet some of the restrictions placed on the motored bikes. You can throttle a two stroke at both ends, by restricting the end of the exhaust of a larger engine you can use the torque produced by the larger bore and still limit the top end. I used to sneak a little hole in the muffler of the little Honda's we used to run around on, I never let on and the rest never could figure out why my bike would always run away from there's. I hope this helps, I have built a lot of engines, and I like answering questions. Have fun, Dave
