Ahh, the CNS Version 2 carb with a separate idle air circuit and bogging problems, I know a thing or two about this, wrote a whole pic detailed instructional topic about this very topic I just didn't do here as I was 'banned for life' 2 years ago because I put my local MB business web address in my sig so I joined the other major MB site and shared it there.
New owner here and I'm back but I can't reproduce the whole "Inside the CNS Carb' topic here, sorry, bit I will share this:
Unlike the nonadjustable needle and idle air circuit on the CNS 1, the CNS 2 has both.
Up until the new 2011 models the black rubber gasket inside the carb intake that butts up against you intake was too short to seal the gap in the carb where you tighten the screw to attach it.
This created an air leak leading to a lean condition, so gasket sealer on that grove once the carb was attached fixed that.
Then there is the idle air adjustment screw...
Again I can't go into the whole tutorial with the illustrations of how the 2 different fuel systems work together depending on where the throttle is I can tell you this:
You need to adjust the idle air mix screw on the left and the overall barrel idle screw on the right in concert to get a smooth idle and real power in that idle to 1/2 throttle range where they overlap.
As others have mentioned you can just get an NT carb for ~$20 from BoyGoFast on e-bay but if you have a 66cc motor you will never get the performance a CNS2 will give you, you just won't have to mess with it much.
JUST A WORD OF ADVICE FOR THIS COMMON PROBLEM
DON'T START WITH MODIFYING THE CARB!!!!!
The CNS2 is too much for a 48cc, don't even bother, but for a 66cc, especially a performance one it is the best kit option and they perform great if you just tune it right.
As for specific advice to get going for you T-lo:
Buy an NT carb as there is no telling what your 'carb fixes' did.
Get a couple new plugs and gap them properly, ~.030 give or take .002 depending on your wiring and CDI. The bigger the gap the better if it will still spark at idle. Just like the Aux circuit on the magneto the spark voltage goes up with RPMs.
Once you get it started and warmed with a short ride up kill the motor at Wide Open Throttle (WOT) and THEN check the plug for color.
If it's dark move the needle clip down a notch and try again.
If it's white move it up a notch.
If it's tan stick a fork in it, your good ;-}
