motor_bike_fanatic
My current build is a cranbrook with a 68.5cc china engine. I am thinking of having my buddy build me a 99cc predator build. to save money, I was thinking of using some parts off the cranbrook. My buddy has a schwinn cantilever frame, but its just a frame, no fork, no headset, no bearing cups in the bottom bracket. no wheels either. I was going to use the fork and wheels off the cranbrook, but only the front rim is original. the back rim is a coaster hub but with 12g spokes and is double walled steel, so should hold up fine. I have a rim brake on the front rim, I was thinking of using that on the predator build, but changing the pads to the kool stop salmon colored ones. I have an extra wide crank on the cranny bb, the kind they sell for use with the cent clutches on the china engines. will those clear the motor? I currently have a 44t rear sprocket, but would change that to a 56t for more torque. my buddy's predator bike does 46mph with the 56t rear and that is plenty fast enough for me. if I can use my wheels, fork and headset on the schwinn frame, that will give me the solid steel frame that a predator bike requires, but also save me a lot of money. 100 bucks for the engine, 300 for the transmission and motor mount, plus whatever the lighting system costs, because I want the same lighting setup he has, and 25 for the frame. that puts this bike at probably around 500 bones. I just need to know if I can use the fork, headset, and extra wide pedal crank on the schwinn frame.
