From what i undersand....
Adjustments in timing advance or retard have the most impact on the temperature of the exhaust gases that exit the exhaust port.
Senario 1 Ignition around 2.5mm before TDC..... (Retarded Ignition Timing)
The combustion process has more time to complete before the exhaust port opens. The hot gas has more time to transfer heat to the piston cylinder and head. So the exhaust gas comes out of the port cooler.
My question is dose this mean the engine head cylinder and piston are actually getting hotter? Since more heat is being transfered to them?
Senario 2 Ignition around .5mm before TDC..... (Advanced Ignition Timing)
The combustion process has Less time to complete before the exhaust port opens. The hot gas has less time to transfer heat to the piston cylinder and head. So the exhaust gas comes out of the port hotter.
My question is dose this mean the engine head cylinder and piston are actually running cooler? Since more heat is being transfered out the exhaust?
The secret of the story..........
In pertaining to the Expansion Chamber this could be a benifit.
Hotter gases move faster.
Cooler gases move slower.
The speed the gases are traveling impacts the powerband of the pipe.
Slower gases put the powerband in lower rpm.
Faster gases put the powerband in higher rpm.
Look at these CDI kits.
Says universal.
Can we use these????
Horse Power Ignition
