Hey Wayne, I seen your bike, and it's a nice one, I really like it. It made me go buy the motor actually so I could have my own. Great work manI haven't removed anything internaly on mine. I have about 600 hard miles on it, revving it to about 5000rpm a lot.
I actualy left the metal piece(bellcrank) in place, hooked the stock spring up to one of the gas tank stanchions to pull the opposite way to close the throttle, and hooked the throttle cable to the bellcrank at the hole next to the throttle rod on the bellcrank.
Did nothing else to the govenor, and it works perfect.
Hey there mesmith,I also would like to know what rear sprocket to use, my bike is a 26 in., I have an AGK drive, with a 11 tooth clutch, 22 tooth input sprocket, 9 tooth output sprocket. It says to use with a #41 chain, I don't know where to find one ?. and I'n not sure which rear sprocket to use, please help , anyone??? It says my ratio would be 12:44:1
Thank You jowens for the information. I live in Illinois and not much as of hills here, so I think the 44t sprocket will be fine for me. I did remove the piece of metal that goes to the governor, so that may give me more rpms and a little more speed.Hey there mesmith,
Ive been planning this build too.....from what Ive researched as far as sprockets are concerned you would need a 56t sprocket to keep a final ratio of 12.44:1 which would give you a cruising speed of 22MPH at 3600 RPM's engine speed.....keep in mind Im quoting you off the max RPM of engine with the governer still in place on the engine.....depending on your situation ie...weight hilly terrain etc...you could drop to a 48t sprocket and get a final ratio of 10.67:1 that gives you a cruising speed of 26 MPH at 3600 RPM's....or drop even lower to a 44t sprocket to give a final ratio of 9.7:1 which cruises you 28.68 MPH at 3600 RPM's.....keep in mind that as you drop your final ratio you are going to lose torque and not pull hills as well as a higher gear ratio....I live in flat florida and only weigh 160lbs so I will be going with the final ratio of 9.7:1.....hope this has helped to answer your question....most people on this forum that Ive seen posting about final ratio recommend a final ratio of 10.5 to 11.5:1 as a healthy final drive ratio.
I didn't remove the metal piece going in the block, or anything else except for the factory fricton throttle lever.Wayne, I removed the metal piece that goes inside the motor, is that what controls the plastic governor?
I believe the motor is rated at 31/2 hp.eBay carries #41 chain, and tractor supply places will too. How many horse do you think this motor can pull? By my calculations, at 3.5 ft lbs max torque at 2500 rpm, that is about 1.6 hp. Assuming 3600 rpm still at 3.5 ft lb, thats 2.4 hp. Not sure about higher rpms, but if the torque is say, 3 ft lb, then thats 2.85 hp @5k rpm. Doesnt seem like all that much, especially with the high gear ratio. :/ Hopefully performance mods will bring that up a lil bit.
40 mph is fas t enough for me...my 2 stroke can hit 43, at least that is what my speedo says.I didn't remove the metal piece going in the block, or anything else except for the factory fricton throttle lever.
I have 2 speeds on my build. Low gear is abour 14:1 and gives about 25 mph at 5000 rpm.
high gear is 9.75:1 and i get about 40 mph at 5000 rpm, and still pulls my 200 lbs up steep hills as long as I have some speed when I hit them to get the engine in it's power band.
I am looking at making a motorised bike with a 99cc preditor engine, where did you get all those perts from as I tried to find them and I couldn'tHey guys I am planning on my predator build and am going to buy all the stuff very soon. I made a list of all the components I think I need. Can anyone tell me if there is anything I could cut or anything I missed? I'm going for lowest cost possible.
Also I will be putting my MTB fork on which has very strong v brake. Thats why no brakes on list.
And what drive ratio should I go for? I would like the motor to cruise without being wound out at 30, but still pull hills well (is this impossible?) as I've got some big ones, not long, but VERY steep. Walking down I think you would roll all the way down if you trip, about .2-.3 miles each.
With the JS at 11/22, would output 9/48 be okay for my purposes? This gives me 29 mph at 4k rpm. Governor removed of course. Is this an okay engine speed? Max at 6k indicates 43.5 (I don't plan on going that fast!). Will it pull hills, or is that too high a ratio at 10.67?
My current chinagirl bike and I weigh a tad under 200, with a 41T I have to heavy pedal assist up these things.
WM HUFFY CRANBROOK: 80
HF 99CC PREDATOR: 110
AGK Jackshaft: 135
AGK CLUTCH: 40
AGK COVER: 45
AGK MOUNT PLATE:25
AGK SHIPPING: 13
AGK TOTAL:::::::::::::: 257
DAX THROTTLE: 13
DAX FUEL VALVE: 4
DAX CHAIN: 12
DAX FUEL LINE: 2
DAX SHIPPING: 9
DAX TOTAL:::::::::::::: 40
PB 2.5 TANK: 25
PB SPR ADAPTER: 60
PB KICKSTAND: 25
PB SHIPPING: 15
PB TOTAL::::::::::::::: 136
TOTAL:::::::::::::::::::613
If yer speedo is one of the cheap analog ones like mine, in my avitar above, you can't trust what it reads. Mine sez 55 when I'm going 40.40 mph is fas t enough for me...my 2 stroke can hit 43, at least that is what my speedo says.
pb = Piston Bikes? Same diff really, parts wise.arand,,,here is the 'where he got them' ,,,
wm huffy = walmart
agk = affordable go karts
dax = thats dax
pb = pirate cycles
not sure if any ship to OZ
