If you have a 2 stroke, Chinese engine, you didn't tell us what you have, the white wire will only produce about 6 volts and that is AC (alternating current), and a little less than 3 watts. That isn't enough current to run what you want. Overloading the white wire will shunt power from the CDI (ignition module) and shut down the engine. Go for a rechargable battery for your accesories.So you think that I vcant take power from engine ?
i found it on ebay,the name of the seller is mightywonderful, store :wonderful creations item#400108735081, thats for the complete 12volt set up, 180.00 bucks, but you can buy seperate parts as well.they even have a charger that works off the stock white wire(6v)set ups 30 bucks and up...etc.im not affiliated with them in any way,just found by chance and tryin to spread the word,they should pay me,, lol.hope this helps
