80cc Run in help please
davegoldy
Hi all,
I'm new to this bike engine stuff. I'm cheating a bit and have a bike with new engine fitted delivered.
I have been advised to lube the crankshaft and gears, use octaine boost cleaner for 1st tank. Then after 1st tank used adjust the clutch.
I don't really own any tools at the moment & don't know how to do any of this!
I would like to know how to get to Crankshaft (& how to rekognise it!) and same with gears...then do I just spray WD40 over them?
Then also how do I adjust the Clutch?
Hope some one can put this in laymans terms
Cheers,
Goldy
Pablo
Dec 28, 2007
3,696
33
48
Duvall, WA PNW
www.sickbikeparts.com
Hi all,
Cheers,
Goldy
Some of that just makes no sense. The crankshaft will be lubed by a healthy fuel oil mix. I think they MAY be talking about the crankshaft output gear and the flywheel/clutch gear. WD-40 simply will not do. Take the right cover off (aka clutch cover), and put a toothpaste single brushing dab of sticky grease on top of where the large and small gear mesh.
Octane boost? No - don't waste your money.
Clutch is adjusted also inside the cover, I'm in a bit of a hurry right now, but find Norman's long post on the clutch. Basically, remove cover, remove tiny screw and turn flower nut in to get more engagement out for less......
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Hi all,
No, do as Pablo stated and lube the gears behind the right side cover with A LITTLE grease, wheel bearing grease or lithium will work. use octaine boost cleaner for 1st tank.
Stupid advice, waste of money, don't bother.
Then after 1st tank used adjust the clutch. Waste of time, not needed.
Goldy
Ride it, break it in and if you need any adjustments, just ask around here and someone will definitely help.
