Motor hard starting
Skyline
After replacing piston rings, I can no longer raise rear wheel and kick start bike as before( too much compression ) now I have to ride fast and dump clutch to start. Does this sound normal??
Thanks, skyline Steve
If the piston isn't hitting the plug..which i doubt since you only replaced the rings, I'd add another head gasket or two to bring down the compression. When the rings wear in you might have to remove a gasket or two.
I think I will run it for a bit and see how it works itself in. The motor runs really good, thanks fisherman.
Al's advice is correct but also pedal starts are not that uncommon. I'd say most of us do it. In fact it's the way the engines were designed to be started.
Thanks Tom, I feel good with leaving it alone and running it.
Pedal starting seems so much easier anyway!
