guess I'd better order those jets
You seem to have covered all the other bases, so jetting would be you next logical step. I would buy some various jets and check them out, specially if they are so cheap.
You can also buy a mini drill bit set and make custom jets. If you need to go smaller just solder up the hole and drill out smaller... Probably want to do this with your spare jet.....
thanks NC, have ordered. also gonna try the China 'performance pipe'.
Performance Exhaust Systems Cycle Pro Motors
The going consensus is that adding a tuned pipe slightly enriches the fuel/air mix
Genuine Dellorto jet. 5mm thread for use on stock NT 2 stroke carburetor to dial in proper fuel air mix.I just ordered 3 of those jets & then realized they are for the dellorto or cns carb :-( I have the NT
Shoot them an email. They answer them real fast. These are great guy's to do business with.
The local engine supplier has not been able to supply any .65 thru to .68 jets. They are trying to get some from China. I will try buying the pipe in the meantime. Would be good to find somewhere with Int'l shipping that supplies jets for the NT carb.
Sorry NC Im just a bit grumpy after clicking that link & ordering the wrong jets & paying Int'l shipping for them. Waste of money.
